Battery
(Topic created on: 05-06-2025 02:10 PM)
nicko24
Hi, guys
I'm using a S23 on One Ui 6.1
I want to share the battery information, is it normal or i have a bad battery backup?
Screen off time is 4 hours and 40 min
Screen on time is 2 hours 33 mins
With 80% battery charge
Phone used 63% battery in 7 and half hours
9 REPLIES 9
RedDogRabbit
The Battery Info, right in your screen shot, says the battery is "normal".
If you're using a lot of battery, it's probably something in your app settings. ie: some apps constantly running in the background etc.
Put unused apps to sleep etc.
RobertZ
Decrease the screen brightness way down.
Helenna
Hi nicko24,
Thanks for sharing your battery details.
From your screenshot, the battery status shows “Normal” with “Life: Good,” which indicates that the battery health itself is not the issue.
If you're experiencing higher battery drain than expected, it may be due to background activity or certain apps consuming more power. Here are a few suggestions that may help:
  • Go to Device care > Battery > Usage to identify any high-drain apps
  • Put unused or less-used apps into Sleep or Deep Sleep mode
  • Turn off background data for non-essential apps
  • Consider disabling Always-On Display, and reduce screen brightness or refresh rate if not required
These small changes can often make a noticeable difference in battery life.
Can you let us know if we are going to get one ui 7 in canada for S23 Ultra at all or should we wait for one ui 8 directly. Or should i sell my phone and get a pixel or iPhone
RedDogRabbit
You'll definitely get One UI V7.0 for your device in Canada.. it's already been released in the US & a few other countries... You just have to wait for Samsung Canada to get it's act together.
Wait for how long. SCAMsung is just playing around with one ui 7 and Canada. No April security patch no one ui 7 no update on the dates. SCAMsung is *** now 👎🏻🖕🏻
RedDogRabbit
Very mature... 🙄
Yes I'm. I have paid for a premium product and i have every *** right to expect timely updates and if not given i have every right to show my frustration. Period
RedDogRabbit
Of course you have the right to feel frustrated, but expressing your frustration in a juvenile manner, with words that need to be blanked out, childish nicknames for Samsung, and rude gestures... makes you look incapable of mature thought.. I'm sure that lots of people are frustrated, but you don't see a significant number of them expressing their frustration like you.
