abbatman
04-06-2017 10:14 PM in
Any one know what the difference between My Knox and Secure folder is?
And how to uninstall either?
5 REPLIES 5
Echo1
Expert Level 4
04-07-2017 02:48 AM in
You can't uninstall Knox its a Samsung app for the phone
abbatman
04-07-2017 02:54 AM in
You actually can, i just did it
04-07-2017 11:30 AM in
Hey @abbatman, you can uninstall "My Knox" which is installed from Google Play but KNOX services are a part of the system firmware on your device. Secure folder is essentially a newer version of "My Knox".
Kisa
08-25-2017 11:20 AM in
Do I have to remove all the apps My Knox before uninstalling it?
Kisa
08-25-2017 11:23 AM in
Also, got the notice that Knox is being done away with and being replaced by Secure Folder - will this be done automatically by an update from Samsung?
