edge lighting for messenger
(Topic created on: 10-12-2020 04:14 PM)
sara86
How do I get edge lighting for when I get a message on fb messenger..im trying 3rd party apps and they don't work for messenger
10 Comments
Halston
Hi Sara,
Please provide us the model number of your device.
Go to Settings>> About the phone/Device>> Model number.
sara86
SM-G975W
Halston
Hi sara86,
Has your problem got resolved by following the below troubleshooting steps? If yes, please take a minute and click on Accept as solution to help other members with the same issue.
You can accept the comment as solution by Clicking on 3 dots on the right side the comment >> Tap Accept as solution. If not, please get back to us with the result.
Nishant1
Dear moderator ,
I am also having problem in my edge lighting for messenger in my new samsung galaxy a54 .
Halston
Hi sara86,
Thank you for confirming the model number of the device. Please follow the below steps and check:
> Open Settings icon
> Tap Display
> Scroll down and tap Edge Screen
> If Edge Lighting isn’t already turned on, tap the status switch to it on.
> Show Edge lighting >> choose the application(select app and toggle on for which application you want edge lighting)
Note: Some notifications may not display as the edge lighting depending on the notification
types.
> To customize Edge Lighting, tap Edge Lighting
> To change the appearance of the lighting effect, tap Edge Lighting Style
> Tap Effect
> Tap the effect you wish to use
> To change the color of the effect, tap Colour
> Tap the color you wish to use
> When you have made all your changes, tap Done
> The edge of the screen will light up when a notification arrives.
sara86
hey it didn't work Facebook messager is not on the list of apps..for some reason so I can't get notifications when I get a message on there
Blyshobel
Messenger(facebook) isn't one of isn't one of the apps on the list.. Is there any way to use Edge lighting for Messenger?
csaba_bor
I had the same issue, but I found that if you simply uninstall messenger when your edge lighting is still on, close all applications then reinstall it,  it will start working.
RAGMAN13_S23PLUS
Beginner Level 3
Totally worked, thanks man i appreciate it went ahead and restarted my phone just incase before reinstall...
RAGMAN13 ® 🤘 🤘
