Galaxy S20 auto rotation mode
(Topic created on: 04-03-2022 11:01 AM)
richiev
Hi, I have a S20 5g running Android 12 UI4.0
Since the update whenever I turn on bluetooth, my locked portrait mode switches to auto-rotate.
Anyone else having this problem & any suggestions how to fix this ?
Thx !
15 REPLIES 15
Brantley
Hi, Please follow the wipe cache partition steps given by Tallman and keep us posted.
richiev
Hi ! I did the wipe partition but it did not resolve the issue.
RedDogRabbit
Then maybe backup your device with Smart Switch & Factory Reset.
My S20 Ultra running One UI V4.0 & connected to a Bluetooth device, maintains Locked Portrait Mode as you can see from the screen shot.
richiev
Will do, thank you🙏
PubGalaxy
It looks like it's a common bug for all S20, Note 20 models. The problem becomes irritated. Samsung needs to fix ASAP.
RedDogRabbit
I wouldn't say that it's common, never happened on my S20 Ultra.
Likely to be human error in the Settings.
You can try Clearing Cache from Recovery, and if you still have the issue, backup your device with Smart Switch & Factory Reset.
