Galaxy S6 Autocorrect Problems
(Topic created on: 12-17-2017 07:58 PM)
CharlieJohnson
So the auto correct on my phone has gone all weird. For example, simple words will be auto corrected, and also it likes to capitalize the first letter of the last word like This. What should I do to fix this? No updates have fixed this issue yet.
6 Comments
akoexmo
go to settings, access general management then language and input click virtual keyboard and turn off auto correct or some other thing that you dont like .
Jonathan34
You could also clear your preferences out and then it'll have to relearn. Some things get a little weird after a long time because it's learned from you so if you've made a mistake one time and sent or confirmed the message with the mistake it'll pick up on that and think that's what you prefer lol
CharlieJohnson
See the thing Is, this is how I type things without correcting Them. I wouldn't ever capitalize the last letter of each Sentence.
Jonathan34
All it would've taken is one slip up or even just something else the software picked up on accidentally in your typing style that has just become a reoccurring error lol I had a ton of terrible auto-corrections and just cleared my preferences the other day and it's working great. Like one time I typed th3re and then it would continue auto-correcting there to th3re lol
Nikkii1990
when you're typing an you see the word come up capitalized on the prediction bar hold down on that word you should be able to delete the word.
CharlieJohnson
It makes the autocorrection after, because I type the period or question mark after.
