Good lock task changer and edge lighting
(Topic created on: 02-08-2021 02:46 PM)
jamesy
Apparently the Task changer module for Android 11 may come in March under the Home up module. The edge lighting is supposed to come in the second half of 2021
4 Comments
keagan
Hi jamesy, From Android R OS device including the Galaxy S21 Ultra, you can access the Edge lighting feature in Notifications menu. For this, on Settings, tap Notifications > Brief pop-up settings > Edge lighting style. Although the Edge lighting style feature has been renamed and the access path has been changed, the supported features are still the same as compared to previous devices.
jamesy
Thanks Keagan for the info!!
keagan
You are welcome @jamesy.
If you find my comment helpful, then please take the time to accept it as a solution by clicking on 3 dots and tap on "Accept as Solution" and help others with the same query.
waqqas31
Actually, the "Black Hole" lighting effect is gone.
