Help! How do I delete attachments in Messages/SMS?
(Topic created on: 12-31-2019 10:59 AM)
hopealewis
Hey all, I just moved to Android from Apple and I'm trying to figure out how to delete my attachments in Messages/SMS. Can someone assist?  I dont want to save (already figured that it-but is there a way to do a mass delete?).  Model is Samsung S10.  Thanks!
20 REPLIES 20
hopealewis
Thanks! I will look into this! I use an app (or did on iPhone) called Export SMS where you could download to PC and save as PDF or Excel. Worked beautifully when needed but have yet to give it a go on Samsung. Very much appreciate all your help along with everyone on this thread!
CynicalJerk84
secure folder is amazing an came with my note 8 definitely the best and easiest options.
hopealewis
And where do I find this setting? the secret folder setting? Sorry never had an Android before OR a Samsung!
CynicalJerk84
it came with the phone least it did for the note 8 I believe. my be a download. just search secure folder in the search bar.
CynicalJerk84
or on the Samsung app store
CynicalJerk84
its pre installed on my note 10. go to button order move it to the main drop down panel. then proceed to set up from there.
hopealewis
Found it! Thanks again!
Techpro
Hi hopelawis. go to button order move it to the main drop down panel. then proceed to set up from there. You might find it quickly have a good day.
CynicalJerk84
literally said that already
Chrissyyy
if a message has been delivered but not read.. can I delete it without the recipient seeing it?
