Help! I keep getting randomly redirected to websites
(Topic created on: 06-04-2022 04:18 PM)
Tibee
Ive donr a malware scan on my phone and it said it was clear and I haven't downloaded any files from the internet, its starting to get annoying and I dont know how to fix it
4 REPLIES 4
RedDogRabbit
What device & One UI version is running on your device?
What kind of websites are you getting redirected to?
Does anyone else have access to your phone?
You should change your passwords & Enable 2-Step verification for your device.
You can try Booting into Safe Mode & see if the behaviour continues.
If it doesn't, then it's likely that the problem is coming from a 3rd party app.
You should know that not ALL apps from the Play Store are 100% safe.
You could always backup your device with Smart Switch & Factory Reset. But when you backup, only backup the apps that you KNOW are safe & that you recognize.
Tibee
My phone is a Samsung S21 and UI is 4.1.
The websites im getting redirected to arent inappropriate ones theyre more like articles? Like this one: https://xilxi.com/4019.html
I also have 2 step verification aswell as I use a password generator for my passwords so nothing is really the samr acroas anything, and even then I still need to co firn it on my phone by pop up or sms
Someone told me to erase all data on all my browsers so I did and so far I havent been redirected, but I'll see if that fixed the problem later on
By-tor
I also have a S21 with the same issue. I have deleted all data and tried many supposed solutions with no luck. Someone please help!
Helenna
Hi Tibee, we are glad to see that your issue is resolved.
Please write back to us if you require any further assistance.
