Help with a driving routine
(Topic created on: 02-01-2023 09:09 AM)
Samus08
I have tonnes of data on my phone plan.
My vehicle has wifi but is limited to 2gb of data.
The vehicle gets cel reception in places that my phone doesn't.
I have my phone set to NOT automatically connect to vehicle wifi so it doesn't use up data.
I manually connect to vehicle wifi when I lose reception on phone.
Is there a way I can set up my driving routine to connect to vehicle wifi when cel reception is 1 bar, and disconnect when have 2 or more bars of reception on phone?
5 REPLIES 5
I don't know if this will work for you or not. Please try using Modes and Routine to see if it resolve your issue. I attached a screenshot that may help you.Screenshot_20230201_103530_Modes and Routines_1000022954_1675272930.jpg
Helenna
Hi, yes you can try to use Modes and Routine as suggested by Tallman and check if it helps.
Thank you Tallman.
Samus08
I want to run the routine if mobile network is one bar. It doesn't look like that is possible. I can only base the condition (on wifi strength).
Oh...sorry, I misread your question. I think it is not possible for Mobile signal strength.
Samus08
Thanks for trying.
