How to add flashlight on the edge panel
(Topic created on: 02-27-2017 09:06 PM)
zia
Someone asked this question and I could not attach the screenshot in reply so just created this new post as a tip. On the edge, it's available in the "Quick Tools" panel (also on the panel are the compass and ruler function) From the bottom of this panel you can choose what to display from Torch, Compass, or Ruler. Added bonus, you can adjust the strength of flash light too108e375c-5487-4acb-9c74-c5c37c2abd18.jpg
2 Comments
Brando
they should add image responses
Moderator_
Hey @zia, thanks for the helpful tip! @Brando, can you add that as a "suggestion" topic in Members? (Sounds like a helpful feature). Thanks!
