navigate folders with sound picker
(Topic created on: 03-24-2024 07:48 PM)
cclark_stj
I would like to set an audio file as custom ring tone for some of my contacts.  However, I'm unable to navigate to a file in a folder using "Sound Picker."  I have 650 GB of audio on my SD card,  and have put clips of portions of these converted to "low-fi" mp3 and put in my "Notifications" Folder in Internal memory.   if "Sound Picker" had navigation like "My Files" I could find what I want easily, but it  doesn't - I can't seem to make it do this.  Any ideas?
3 REPLIES 3
Helenna
Hi, please visit the given link to set a custom ringtone for a contact on your Samsung Galaxy phone.
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-set-a-ringtone/
Thank you.
RobertZ
Why can't you get a person from Samsung with adequate comprehension skills to assist your users. Because your bot-like replies are useless.
RobertZ
For me (One UI 6.0), adding a ringtone using Sound picker "folder" only lists the music folder.
For my custom ringtones, I used My Files to create a folder called Ringtones and then I put the audio clip files in there. These files will show up in ringtones listing under a section called Custom.
