Resolved! Solved
Notifications not making sound or vibrating
(Topic created on: 02-05-2022 06:04 PM)
esor
S20 Plus
Since the recent update (Feb. 2022), my notification sounds have not been making noise.
My volume is up full blast.
I've done diagnostic testing. All passed.
I have gone in the notification settings and double checked everything.
They were working fine until update.
Also, have had my phone just stop working while on a call. I can't hear them, they can't hear me. Was having a lengthy conversation, after 50 minutes my phone cut out and I had to do a reset and call them back.
What's with the issues of this update?
How can I fix these issues?
Try go to recovery mode and do a wipe cache partition:
- Power off your phone
- Press and hold vol up and power key until you are in recovery mode
- use vol up and down to navigate
- select Wipe Cache Partition
- press power key to confirm
- click yes
- click reboot system
5 REPLIES 5
- click yes
esor
Thanks. This did work.
Glad to hear your problem resolved.
damahs
Had the same problem and when i did it it didnt work
Reynaud
Hi esor, we are glad to see that your problem got resolved. Thank you Tallman.
