Persian Keyboard Problem
(Topic created on: 03-11-2020 09:44 PM)
mamaj
In persian (Farsi) keyboard, the letter ى has a huge problem. When connected to another letter, this letter should change its form from ى to یـ but this is not happening correctly, which is extremely annoying.
Does anyone has the same problem?
12 REPLIES 12
johngcan
Not for me
SamAnna
Works fine for me من هیچ مشکلی ندارم
Jeremie
@mamaj,
Please provide which keyboard application you are using and try to remove and re-add the Persian(Farsi) language from the keyboard.
mamaj
I am using the Samsung Keyboard on Galaxy S20+.
I re-added Farsi and the problem didn't resolve. I also tried clearing keyboard's data and adding Farsi again, still no change.
NavidVera
Same issue here on Galaxy S20+, following this thread
Pooyarad
من هم همین‌ مشکل رو دارم.
I have the same problem
This is how it types
اىن
But correct way is : این
So the keyboard types  ى  instead of attached version of this character
alirezaten
Beginner Level 4
Same problem on My S20+
Not applicable
Yes i am facing the same problem on my newly bought S20+
alirezaten
Beginner Level 4
Problem fixed in last update.
