Poor battery on Samsung S23 ultra with update
(Topic created on: 05-31-2025 05:33 AM)
fox2
My turn ... Did the update yesterday on my ultra and wipe the cache .... Ans still ***.... Can we return to the old one ? Can't believe Samsung Gave us that s...
3 Comments
Autumnpigeon
I have issues too. My battery is at 100 at 0600 by 1800 I have 30 at normal use. I've had my S23Ultra for 2yrs it's after the update this started happening
fox2
😮 can use my phone for few hours now... Loôol before it was good for 1 day and half 😂
Helenna
Hi fox2,
We're sorry to hear you're having battery issues after the update on your Galaxy S23 Ultra. After a major update, it’s normal for the system to take a few days to optimize in the background, which can temporarily affect battery life.
You've already wiped the cache, which is a great step. We also recommend checking for any apps using excessive battery in Settings > Battery > Usage since last full charge, and updating all apps via the Galaxy Store and Play Store.
Unfortunately, downgrading to a previous version isn't officially supported. However, we're actively collecting user feedback, and your experience will help improve future updates. Please consider reporting this through the Samsung Members app > Support > Send feedback so our team can investigate further.
Thank you.
