problem
(Topic created on: 11-02-2025 07:33 PM)
s24user_0
Is it normal that every time I use the TikTok app it consumes 5 GB or even a lot of RAM? I've had this problem for a long time. Is it normal that every time I use the TikTok app it consumes 5 GB or even a lot of RAM? I've had this problem for a long time, even though I have the S24 Ultra with 12 GB of RAM.
10 REPLIES 10
oozi
Im pretty sure its because of how samsung preloads apps, since it's a 12gb phone, it will load alot of apps or alot of an app, and since tik tok is probably an app you open alot, it might keep it preloaded because it doesent want to have any "wasted" (unused) ram
s24user_0
And how can I prevent that from happening?
oozi
Im pretty sure you can't, and its a "no problem" because if the phone needs to use more ram, it will unload the other apps off of its ram
oozi
But I'm not expert tho
s24user_0
The problem is that TikTok starts to lag the more RAM it consumes.
oozi
tik tok allows for 120fps videos and in full HD, it does cause some phones to start lagging-even the high end ones
I think you should clear the cashe of the app to clear your ram
RobertZ
Some apps are like that. They leak memory and get sluggish. Sometimes you cannot do anything but restart the app.
Urmi
Hi s24user_0,
No, it's not typical for TikTok to consistently consume 5 GB of RAM on the Galaxy S24 Ultra. While the app can be resource-intensive, such high usage may indicate a software issue, background process overload, or poor optimization.
How to Check and Manage RAM Usage
  1. View App Memory Usage
    • Go to Settings > Battery and Device Care > Memory > Apps using memory.
    • Check TikTok’s real-time and background usage.
  2. Clear TikTok Cache
    • Go to Settings > Apps > TikTok > Storage.
    • Tap Clear Cache (avoid Clear Data unless you want to reset the app).
  3. Disable Background Activity
    • In Settings > Apps > TikTok > Battery, set it to Restricted to limit background processes.
  4. Use Device Maintenance Tools
    • Run Device Care > Memory > Clean Now to free up unused RAM.
  5. Update or Reinstall TikTok
    • Ensure you’re using the latest version.
    • If the issue persists, uninstall and reinstall the app to reset its behavior.
  6. Monitor with Good Lock’s Memory Guardian
    • If you use Good Lock, install Memory Guardian to track and manage RAM usage more precisely.
Jetsgirl66
Sorry, but I don't do TikTok. I hope it works out for you though.
