retrieve deleted voice recording on s7 edge
(Topic created on: 12-01-2017 03:12 PM)
961canada
Beginner Level 4
hi
i accidently deleted the voice recording of my lecture (from downloaded app called voice recorder) on my s7 edge as it was over storage
is there a way to retrieve pls ?
thx a lot
6 Comments
shaggyskunk
Unless you have something set up to automatically upload to a Cloud account - I'm thinking that the only chance is if you have an eidetic memory.. 🐧
961canada
Beginner Level 4
thanks but how can i retrieve from cloud pls ? never did it
i mean i set up the option to sync with cloud but never had to use it. pls help if possible
thx
shaggyskunk
Google is your friend 😉
https://www.samsung.com/us/support/owners/app/samsung-cloud
961canada
Beginner Level 4
ohhh thanks a lot 😁
A11
@961canada is it not in "My files"-Samaung cloud
if its not on the cloud or synced with google, then unfortunately, it is gone.
