S21 ultra UI4.1 battery
(Topic created on: 10-18-2022 05:19 AM)
MG77
Just had this update, seems as if the battery is draining considerable faster....anyone else ? And I'm only running FHD mode not WQHD
6 Comments
RedDogRabbit
I always Boot into Recovery after any Security Patch Update & Wipe Cache. See if that works for you.
Here's the instructions for Wiping Both Cache and a Factory Reset if you want.
Power of your device & Wait a few seconds.
Press & HOLD the Power + Volume UP buttons, until you feel the device vibrate. Release BOTH buttons & wait a couple of seconds until you see the Recovery Menu.
Use the Volume button to Scroll down to Wipe Cache & Select with the Power button.
Wait a few seconds until the Recovery Menu Defaults to "Restart Now" & Select with the Power Button.
Your device will Reboot.
Factory Reset is the same as above, but instead of Selecting Wipe Cache, you Select Wipe Data Factory Reset.
BEFORE you Factory Reset, BACKUP your device with Smart Switch.
When your device Boots up, it will be to the Welcome screen, same as when you first received your device as new.
⚠️You'll need to know your passwords etc, So write them down if you need to⚠️
MG77
Thank you for the auggestions for my issue. I did the cache clearing and unfortunately it didn't seem to improve the condition very much. Normally having my phone in "bed time " mode I might loose 2-4 % overnight I lost almost 10%. My S21 ultra is not 2 years old yet.
So my next question is a factory reset really going to help ?
RedDogRabbit
You can always check the Battery's health using the Samsung Members app. Click on Support & Diagnostics, run the Diagnostics for the Battery and see it's health.
If the battery is "good", and you are pretty sure that it's draining faster than usual.. Short of visiting a Samsung Service center, or replacing the battery, a Factory is what I would do.
MG77
Thanks RDR, seems like a daunting task to do factory reset...🤪
I checked battery as well as you suggested.
RedDogRabbit
If you backup your device with Smart Switch, it's actually not too bad.
I have a bunch of apps that require me to use adb to enable them to work, and even with that, it doesn't take long to get my device back to how I want it.
Just make sure that you either select "All" or if you use Custom backup in Smart Switch, that you tick everything that you want backed up.
If you're nervous about important files, photos etc, you could always copy them to your computer before you Factory Reset, but I have never lost anything with Smart Switch.
Helenna
Thank you RedDogRabbit.
Hi, as suggested by RedDogRabbit, please perform Wipe cache partition and if it doesn't resolve the battery draining issue, kindly back up and factory reset your device by following the steps in the given links.
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-back-up-and-restore-data/
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-perform-a-factory-reset/
