S23 ultra problems
(Topic created on: 03-31-2023 09:16 AM)
Kedhar
Finally I received my Ultra
I am samsung user since 13 years
The problems I noticed in my Ultra are
1. Adaptive display is not working properly, poor or washed out colours in general use, under bright sunlight its struggling to maintain colours, while taking pictures under bright sunlight( gross or trees) , camara view finder shows bright and high contrast green, but suddenly it will shift to washed out green
I think this is the problem with HDR display management (I have noticed this issue in some led TV's with Hdr support)
2. Twitter scrolling is not smooth
3. Camara is inconsistent
these are major issues I found in my daily usage
Coming to positives, everything is best as of now, impressive camera shots I found no lag (some people or YouTube reviwers complained)
Hope march month end update will fix issues or it may adapt to my using conditions..
Already Korea released update around 900mb size with camera improvements.
Please comment bellow if u have faced same issues
14 REPLIES 14
Kedhar
I forgot to write, bixby text to call function is not working.
Any suggestions to make it work?
Hi @Kedhar you need to enable it (if you haven't already) from the Dialer app.
Open the Dialer, tap on the 3 dots 8j the top right, then select Settings.
From here, tap on Bixby text call then tap on the slider to enable it.
You will also need to download the US English language files.
Screenshot_20230331_153754_Call settings_1000003989_1680237556.pngScreenshot_20230331_153744_Call settings_1000003988_1680237564.png
Kedhar
Thanks mate,
I did this, it's not working
Does it work with only unknown callers ?
In my previous phone it used work with all numbers..
In my own testing (before the US English support was added) it worked for all numbers, private or otherwise.
Have you "killed" any other Bixby services?
Also, you could try clearing the Dialer app cache.
Kedhar
I did reset too, no luck..
If you check my original post about Bixby text call, here:
https://r1.community.samsung.com/t5/members-star-s-corner/bixby-text-call/td-p/19321892
Are you not getting those icons in the dialler screen when you get an incoming call?
Kedhar
No, I m not getting that option
Ok, that's really odd.
I'm not sure what else to try currently.
I think you should send an error report to Samsung via the Members app.
To send an error report:
Samsung Members app > Support > Error reports > select issue category > Describe issue and frequency > Tick ‘Send system log data’ > ‘Send’ in top right.
Troubadour
For 1. Can you still adjust the brightness bar when adaptive display is on?
For 3 see my reply post in today"s forum "Samsung S23 blurred video rear camera" or something close to that wording.
