S23 ultra problems
(Topic created on: 03-31-2023 09:16 AM)
Kedhar
Finally I received my Ultra
I am samsung user since 13 years
The problems I noticed in my Ultra are
1. Adaptive display is not working properly, poor or washed out colours in general use, under bright sunlight its struggling to maintain colours, while taking pictures under bright sunlight( gross or trees) , camara view finder shows bright and high contrast green, but suddenly it will shift to washed out green
I think this is the problem with HDR display management (I have noticed this issue in some led TV's with Hdr support)
2. Twitter scrolling is not smooth
3. Camara is inconsistent
these are major issues I found in my daily usage
Coming to positives, everything is best as of now, impressive camera shots I found no lag (some people or YouTube reviwers complained)
Hope march month end update will fix issues or it may adapt to my using conditions..
Already Korea released update around 900mb size with camera improvements.
Please comment bellow if u have faced same issues
14 REPLIES 14
Kedhar
Thanks mate,
Yes I can adjust the brightness
Troubadour
For Bixby Google "Samsung clear Bixby cache". Treat with care,clearing data or cache will delete your other Bixby settings. One reply indicates that there is both Bixby and Bixby voice but I haven't checked that. If you hàve had a recent update this sometimes leaves remnants in the cache which interferes with updated software.
Kedhar
I did a reset after upgrading to new firmware, still same, I will try clearing cache. Are you able to use bixby text to call with English?
Troubadour
I am allergic to Bixby, I don't use it 🤣
