S23Ultra, can not connect to a U7Pro wifi 6e exclusive network. Via WPS3 PMF
(Topic created on: 09-06-2024 08:24 AM)
Kamak
I have three Ubiquity U7Pro with a setup exclusive radio wifi 6e on each and I can not connect to it with my S23U. I've tried everything that I can think of, but it continually says I have the wrong password. What am I missing.
1) factory reset phone.
2) set channel width to all possibilities.
3) set channel to auto
4) ?
Wifi 6e/7 is exclusively WPS3 with PMF, can not be changed...is this the issue with the U7Pro?
5 Comments
Helenna
Hi Kamak,
The issue might be due to WPA3 and PMF compatibility with your Ubiquity U7Pro. Try these steps:
  1. Ensure MAC randomization is disabled on the S23 Ultra (use "Phone MAC").
  2. Separate the SSID for the 6 GHz band.
  3. Check for firmware updates on the U7Pro for improved WPA3 support.
  4. Test if other devices connect to isolate if it's an S23 Ultra-specific issue.
If problems persist, please consider reaching out to Ubiquity support.
Thank you.
Kamak
Yup did tip #1 and #2, and #4 for sure. I'll double check to see if there is a new firmware, pretty sure it's up to date.
Need to get a second S23U in here to check compatibility.
Nkair19
Any luck?  I am having same issue.
Kamak
I got bit to work quite a while back, by allowing/using the beta/experimental updates. I would have thought the regular release updates would have fixed this by now. What U7Pro update are you on?
Kamak
In Settings / Updates/ Device Firmware Release Channel/ Early Access and, Device Firmware check Allow Early Access Release Channels
On 7.0.77.15964
