kronosOC
08-05-2017 06:03 AM in
I'm having a problem with getting group mms/msm in a group all I get is watch contact sending a sepreat msg with h is stupid why or how to fix so all group mms show up in one conversation.
2 Comments
Echo1
Expert Level 4
08-05-2017 07:49 AM in
When you in the app and go to write a message at the top there are 3 tabs one is group's and then once it is open it will show you your groups i.e. family etc just great a group let's say.. Ian's 40th and add contact to that group...
Or just compose with multiple contacts...
Homie9
08-08-2017 09:52 AM in
Unfortunately, unless all your contacts are using an Android device, group messages may not function as intended.
