Samsung dex wont work with s25ultra anymore
(Topic created on: 02-11-2025 12:07 AM)
Ja551e
Hi i had s22 ultra before which i traded in, when i used to click dex in quick panel and my computer app samsung dex used to open dex mode
Now i got s25 ultra and i have opened samsung dex on my windows pc and i click dex in quick panel it doesnt show anything even with wire and wireless nothing works.
10 Comments
PókeDynamax
S25 on One UI 7, and they drop support for Windows. You will need to find an alternative. Affects only one ui 7. You can use Windows 11/10 Windows Connect, Samsung flow, and link to Windows, or do some search on subreddit samsung dex section.
Ja551e
I guess back to windows connect
jjarchow
Even with a USB-C dock connected to the HDMI into a monitor I cant get any form of wired dex to work, the only way it works is wirelessly connecting to my Samsung TV
PókeDynamax
Don't hijack someone post. If you need help then start posting a new topic. Thank you.
Fatwa
I used Dex with my S25u on Sunday. Worked fine.
Ja551e
With dex app on windows comp. ?
SeamusDelion
Ja551e
Not with tv, with windows comp. Doesn't work
Zaidy2329
Beginner Level 4
I tried with the TV and Windows. Works perfect 🔥
