Samsung Flow typing issue
(Topic created on: 07-30-2021 12:02 PM)
St3ady
When I use my phone, everything I type shows up perfectly. Whenever I type on my computer on a different app, everything I type is accurate. Whenever I use my PC to type on Samsung Flow, however, the only characters that will enter are a weird looking B (currency sign?) and an apostrophe. The keyboard is set to English and I didn't change any settings. How do I return the typing back to normal so that I can actually use Samsung Flow?
8 Comments
St3ady
On further testing, typing works fine on Snapchat. However, whenever I open Facebook Messenger or my Messages app for SMS, I select the textbox and the Samsung keyboard opens up. When I type, it enters in one character, minimizes the Samsung keyboard, and then doesn't let me keep typing unless I click the textbox again. So now I have it working, but only one letter at a time.
Halston
Hi St3ady,
Welcome to the Samsung Members Canada community,
Samsung Flow delivers a seamless, secure, and connected experience between your smartphone and tablet or PC. Authenticate your tablet or PC with your smartphone, share content between devices, sync notifications, and view smartphone content on a larger screen.
Setting up Samsung Flow
- Search for Samsung Flow in your apps list on your PC or Tab and Galaxy Phone
- On your PC or Tab click Start
- Tap on Agree on your Galaxy phone
- Select your Galaxy phone
- Choose how you would like to pair the two devices - either using Wi-Fi or LAN or Bluetooth
- Confirm the passkey on both your PC or Tab and mobile
- Once the pairing between your PC and mobile are complete, you will be able to use Samsung Flow
The following devices support Samsung Flow:
- Windows Tablet/PC: Windows 10 OS Creators update (V1703) and June patch build (15063.413)
(Galaxy TabPro S, Galaxy Book, Galaxy Book2, Galaxy Book S, PC)
- Android Tablet: Android N OS or newer
- Android Phone: Android N OS or Newer
It may not be supported by some models, depending on the smartphone specifications.
* Samsung Flow will operate only on official software released by Samsung Electronics.
* Windows: Bluetooth (Bluetooth LE optional) or Wi-Fi/LAN, Wi-Fi direct
St3ady
Now I am having issues with key recognition. My "z" and "y" keys have switched in the Flow app. Also, my character keys are typing alternate language variants of letters. Trying to do a question mark on my keyboard also inputs an underscore into the Flow app. The keyboard works fine in everything but Samsung flow. Software and everything is up to date, and installs went smoothly. Still having issues.
TaiD7
I have similar problem for Thai Language in Samsung Flow when connect and use keyboard from PC/Notebook. Some of the key are not at the proper one (position). Asking to Samsung rep for months, since Apr 2022, still unsolved.
jwbird46342
Beginner Level 3
That really doesn't address the issue of the keyboard problem randomly stopping.  We wouldn't be experiencing issues if our phones weren't connected.
Why does Samsung Flow randomly stop allowing the computer keyboard to be used?  I *constantly* have to shut all Flow windows down, close the app, disconnect/reconnect the phone via USB cord and relaunch the program.  This is a *serious* issue that needs to be fixed ASAP!  This happens no matter the connection - USB, WiFi and Bluetooth.
David2066
The response 30 July 2021 isn't an answer.
I am encountering more & more problems with Flow.  It doesn't matter which app I use, text, email, Facebook etc.  it stops working with the PC keyboard after a random amount of time.  I've reinstalled Flow on my PC and phone whether it's USB connected or Wi-Fi.
I use Flow for accessibility reasons and this is getting to the point I am considering going to the dark side and getting an iphone.
Come on Samsung  give a proper solution!
jwbird46342
Beginner Level 3
Mine has been doing that as well. ANNOYING!!  I have to disconnect/reconnect constantly  - sometimes within a span of 5 minutes.
Boof_Rog
I switched my keyboard mode to float.  Problem solved.  But... I know that's not an actual fix, regardless, it's better than before 😜
