Samsung S23 Ultra Bluetooth issues
(Topic created on: 02-28-2023 06:15 PM)
Viper27
I had the S23 Ultra for a week and there's an issue when I turned on Wifi while connecting to my JBL Flip 6 there's a cutout on the sound when I moved the speaker like 4 - 5 meter. Then the problem solved when I turned off the Wifi. I had no issues with my S23 Plus even when the Wifi and Bluetooth is on. Anyone experiencing this? I'm using Wifi 6 on 2.4 ghz btw
9 Comments
Viper27
And the strangest case is when I connect to my TWS even the Wifi is on I had no cutout at all. I don't think my speaker is the problem since my S21 Ultra and S22 Ultra worked just fine. Hopefully there's a software update to it
MPP_Q8spDect
I think
even Bluetooth speakers may need software update, but usually operate on silent mode
It could be there is no update yet for new S23 software system for some speaker's software
Something like updated bt "driver"
MPP_Q8spDect
You can also
Wipe Cache Partition
and
Repair Apps
In Recovery Mode
Regularly
to attain full Functionality of your
S23 Ultra device
and
Performing optimally
You may need to do these cache cleaning process each time :
Before Update
After Update
on any suspected glitch
before large file download
After large file install
on any abnormal battery drain
on each abnormal heating issues
after playing games
after any changes in the system
This operations may install new compatible drivers silently
and free up storage space significantly for your convenience
So as to make your device working perfectly
https://youtu.be/AfIaBbS-bVk
MPP_Q8spDect
There is a good habit you can develop
Go to
Setting -> Device Care -> more options -> About Device Care -> Update Security Engine
Once updated
Go to
Device Protection -> Scan Phone
Wait until it's done
And you're good to go .
This may silently give necessary patches needed
Viper27
Update :
When I used 5Ghz on Wifi there's no cutout on the sound at all. I assumed the 2.4Ghz causing the cutting out. I hope there's software update soon to fix this issues
Moderator3
Helloo Viper27, for the solution that you are experiencing has been answered by MPP_Q8spDect. If you have further questions, you can ask via Live Chat at Get Help Tab. Thankyou!😁
Viper27
Nope that's not the solution. Samsung needs to update the device that's it
Tengo el mismo problema
