Samsung S24 offline radio Installation Regarding
(Topic created on: 04-21-2024 11:06 PM)
agent047
Recently I purchased a Samsung S24 but we checked the radio app but I can't find it, if 3.5mm jack issue, there is no radio. Some Samsung mobile SM-A156 this phone have a C-type jack and radio apps are available why is the S24 not available?
And what is the process of installing the radio official app?
#SAMSUNG,#RADIO #S24
4 Comments
RedDogRabbit
There is no "Offline" radio in the S24 series (hasn't been one in North American models for some time).
You can download Radio Apps from the Play Store, for use with WiFi / Mobile Data You would need to use the Type C USB Adaptor for Wired Headphones / Buds, if Wired is your preference. I think that most people just use & actually prefer to use Bluetooth Headphones / Buds.
Helenna
Hi, as said by RedDogRabbit you can download any third-party Radio Apps from the Play Store.
If you prefer wired headphones, you can use the USB-C port on your device to plug in a pair of wired headphones.
Savox326
I hope that you will find my comment useful. So, Samsungs without 3.5 jack really don't support offline FM radio at phone side. But it's supported by headsets side. Headset must be official for the Korean market, these ones also do have big inscription "FM" on USB-C plug. Second condition, your phone must be flashed on Korean firmware or you need root it and activate some configs in system. I already successfully activated FM on Asian Note 20 Ultra and on EU small S23
Again. Firstly, you need Korean version headsets. Secondly, you need FM supporting firmware (Korean) on phone or you have to enable that manually with root
RedDogRabbit
Unfortunately, your post is not useful in any way.
First of all, North American Snapdragon devices cannot be Rooted.
Secondly Running Korean Firmware on a Canadian device just won't work.
