Samsung voice input issue
(Topic created on: 10-08-2024 05:51 PM)
M_R_M_XL
How come when I use the voice dictation from Samsung? And I ask it to put a punctuation in instead of putting the punctuation, and it just spells out the word. Is there a way to disable this or change it? So when you want a punctuation, put in you say that punctuation, it will actually put it in instead of spelling, the word out
2 REPLIES 2
Helenna
Hi M_R_M_XL,
It sounds like you're experiencing an issue with the Samsung voice dictation not recognizing punctuation commands and spelling them out instead. This can happen due to the settings in the keyboard's voice input or a misinterpretation by the dictation system.
You may need to adjust settings in the voice input configuration.
  • Open Settings on your phone.
  • Go to General Management > Keyboard List and Default.
  • Tap on Samsung Keyboard > Voice input.
  • Ensure that Automatic punctuation is turned on (if this option is available). This allows the dictation tool to properly handle punctuation.
If there's a temporary glitch, clearing the cache of the Samsung Keyboard app might help resolve the issue.
  • Go to Settings > Apps.
  • Search for Samsung Keyboard.
  • Tap on Storage, then Clear Cache.
If the issue persists, you can boot into Safe Mode to check if any third-party app is interfering.
  • Hold down the Power button and tap Power off.
  • Tap and hold Power off until you see Safe Mode.
  • Test dictation in Safe Mode to see if it works correctly with punctuation.
Thank you.
M_R_M_XL
First of all, I tried everything you said and the first option there was no automatic punctuation option that wasn't there.The second option in the apps.I went exactly like you said, there was no option to click on samsung keyboard.It wasn't even there, so I couldn't clear the cash unless you know it's listed as something else and I went into safe mode and boy dictation for samsung.Didn't even work there.Even with mobile data on just wouldn't respond, it would activate, but no words would be written so I don't know what the issue is here
