07-03-2025 08:50 PM in
Galaxy S- Mark as New
07-04-2025 06:28 AM in
Galaxy SHi ShriHari,
If the long press on the Side Power button stops responding, even after trying Safe Mode and a reset, please try the following steps:
Check Side Key settings: Go to Settings > Advanced features > Side key. Ensure "Press and hold" is set to your preferred action (e.g., Power off menu or Wake Bixby).
Clear One UI Home data: Settings > Apps > One UI Home > Storage > Clear cache (then check behavior).
Software update: Ensure your device is on the latest software version (Settings > Software update).
Submit an Error Report: Open Samsung Members > Get help > Error reports > Buttons > Describe the issue. Long-press the button when prompted so logs can capture the malfunction.
Your report will help the development team look into it directly.
Thank you.
07-04-2025 06:31 AM in
07-04-2025 06:38 AM in
We are glad to hear that the above steps worked for you and your issue is resolved.
Please take the time to accept the comment that you find helpful as a solution by clicking on 3 dots and tap on "Accept as Solution" and help others with the same query.
Thank you.
