Weird bug after using forced dark mode in developer options
(Topic created on: 09-11-2025 07:04 PM)
Datguy1030
My lock screen was normal the calender was white text and the widgets were colored like their normal widgets. Then I turned on forced dark mode in the settings and noticed it changed my lock screen, when I turned the forced dark mode off it didn't change back.the home screen picture is reference to what the lock screen widgets looked like
1 REPLY 1
Urmi
Hi Datguy1030,
We understand that you wish to revert to the standard widget view after disabling the forced dark mode. We recommend resetting all settings on your device and after resetting the device, Performing a simple restart of the device can often resolve minor system glitches and help ensure that theme changes are properly applied throughout the interface, including the lock screen.
If the issue still persists, please reach out to the community. We will help you further.
