Mute Recovery Problem and fix
(Topic created on: 08-13-2018 12:06 PM)
JcGilmour
Others
If you enable Mute from the pull down when you go back and want to disable mute the same way you have to push the speaker icon twice more. (software failure) Check under settings/sound to verify.
4 REPLIES 4
Others
Are you talking about the Do Not Disturb Toggle? If so - No such issues on any of my Samsung devices - Are you using any 3rd party volume apps? 🐧
Moderator_
Others
Hey @JcGilmour, could you please provide more details to the issue please? Thanks!
- Wonchul
JcGilmour
Others
I am talking about the speaker icon on the pulldown (system settings). the icon has three modes.
flossy1
Others
This is my 2nd galaxy with the same problem. I can't put the phone to.my ear, it goes to mute. How do I disable mute
