08-17-2021 06:33 AM in
Samsung DeX- Mark as New
08-17-2021 09:16 AM in
Samsung DeXHi, please try the below steps and get back to us with the results.
Reset the wireless connection for the Bluetooth device.
On the phone, open Settings, tap Connections and then tap Bluetooth.
If the Bluetooth device is paired, unpair it by tapping the Settings icon next to the Bluetooth device, and then tap Unpair. Now, pair the Bluetooth device again.
If the Bluetooth device is still not working, you can try restarting DeX and then checking for available updates.
Also, try to adjust mouse settings. In DeX mode, navigate to and open Settings. Select Samsung DeX, and then select Mouse/trackpad. Use the slider to adjust your pointer speed.
Select Primary mouse button to change the main button to either Left or Right. Select Flow pointer to phone screen to allow the pointer to move from the DeX screen to your phone screen.
08-17-2021 09:19 AM in
08-17-2021 12:36 PM in
Samsung DeXHi, We request you to register an Error Report from the Samsung Members app by attaching the system logs.
Open the Samsung Members app>> Menu >> Support >> Send feedback >> Error Report >> Send system log file.
With these logs, our team could analyze the performance and errors on the device and if there is anything related to the Samsung update that you have installed recently, we would push a fix through an update.
01-12-2024 03:10 AM (Last edited 01-12-2024 03:18 AM ) in
Samsung DeXAuviPal G9 Backlit 2.4GHz Wireless Air Mouse Remote with QWERTY Keyboard, 5 Programmable Keys and Build-in Rechargeable Battery for Nvidia Shield, Android TV Box, Streaming TV Stick and More https://a.co/d/i79qger
