Resolved! Solved
Voice input help again
(Topic created on: 02-08-2023 06:01 PM)
Joshuac22
Solutions & Tips
Am I the only one that thinks that there should be a diagnostic test specifically for voice input. Mine constantly doesn't register and puts "is" at the front of all my sentences. I don't have a lisp, my phone is 3 months old iv cleared my cache again and again iv reset my phone. But still have the same problem all the time its VARY frustrating
RedDogRabbit
Solutions & Tips
Go to Settings > General Management > Text to Speech, if you are using Samsung's Text to Speech engine, switch to Google's. & test.
2 REPLIES 2
RedDogRabbit
Solutions & Tips
Helenna
Solutions & Tips
Hi Joshuac22, as adviced by RedDogRabbit, please change the preferred text-to speech engine to Google Text-to Speech and see if it helps to solve your issue.
