Solar cell Remote control not working!
(Topic created on: 07-01-2021 08:45 AM)
Watsup
TV & Audio
Bought the 65" Q70A QLED 4K Smart TV (2021) two weeks ago.  Seem to be having problems with the solar cell remote control.  It switches on and off fine.  But, none of the other remote control buttons work.  The TV freezes at the last program that was played previously. This has happened twice now.  When it happened the first time, I tried recharging the remote with a power cable and did a reset of the pairing. But, why is this happening so frequently. Please advice. Thanks.
18 Comments
SamsungJon
TV & Audio
Hmm that's odd, @Watsup. Would you be able to check the battery of your remote and let us know? To do so, got to Home > General > Power and Energy Saving > Available Remote Battery
For a more detailed guide, please see here: https://www.samsung.com/au/support/tv-audio-video/use-and-charge-solar-powered-tv-remote/
Watsup
TV & Audio
Thanks SamsungTina.  Battery power seems fine.  I have had this problem three times since buying the TV on June 15, 2021.  Each time, I had checked the battery power and, in fact, charged it with a power cable.  Within a few minutes (less than 5), it says fully charged. Switching the TV on and off is not a problem.  But, once switched on, none of the other buttons work.
SamsungJon
TV & Audio
Hmm, that's certainly unusual, @Watsup. Would you please be able to email us (members.au@samsung.com) with your full name, TV's proof of purchase (such as the receipt), compliance plate and contact details.
If you need assistance finding the compliance plate, please see here: https://www.samsung.com/au/support/how-to-find-the-serial-number/
Thank you.
Gigiosousa
Beginner Level 4
TV & Audio
I bought mine in June....doesn't seem to be an unusual issue....
logiiq
TV & Audio
Hi...I am also having the same issue with my tv remote(different model).Remote turns tv on and off but no other remote functionality works.
Can I get some assistance please?
SamsungJon
TV & Audio
Hi @logiiq, sorry to hear that you're experiencing this issue. Would you please be email us (members.au@samsung.com) with your full name, TV's proof of purchase (such as the receipt), compliance plate and contact details.
Saubacharya
TV & Audio
Hi, am having same issue. Is this resolved? Bought tv in July. Solar remote keeps discharging. And I make sure I keep it inverted for it to charge, but it just doesn't happen.
It's so annoying. You should have kept it normal remote as it was.  At least it worked!
SamsungJon
TV & Audio
Hi @Saubacharya, I'm sorry to hear that you're not happy with your remote so far. Would you please be able to clarify if your remote charges at all? To check your remote battery please do to Home > General > Power and Energy Saving > Available Remote Battery
If it shows as charged, please send us an email (at members.au@samsung.com) with your full name, TV's proof of purchase (such as the receipt), compliance plate and contact details.
Thank you.
Chandv
TV & Audio
The solar cell remote isn't working. The only thing it does is turn the tv on and off. I have charged the remote a couple of times using USB and still none of the other functions work!!!!
