gear s3 classic & daylight savings
(Topic created on: 11-01-2020 07:25 PM)
micahsdad
Wearables
 K so this morning the Yukon went to Mountain standard time. My phone (the s20+ changed no problem to the new time. My watch which is supposed to automatically pair with the phone for time and is 1 hr behind.
 I have gone with the automatic time on phone and set it manually as well. Both ways the watch stays 1 hr behind.
 I have tried turning off Bluetooth on the watch and setting the time manually but when Bluetooth goes back on it defaults back to 1 hr behind. I have also reset the watch back to factory and re-paired it with the phone.
 This is very annoying and frustrating.
 Any assistance appreciated
 Thanks
12 Comments
Wearables
Can you check on your watch, open Settings → General → Date and time
Is it set to Synced with phone?
micahsdad
Wearables
yes it is set to sync with phone
Wearables
Is your phone also set to Automatic for Date and time?
micahsdad
Wearables
I have tried it both set to automatic date and time and also set the date time and timezone manually
Wearables
If time synced with phone, time should not 1 hour behind. 🤔
Wearables
Oh...just saw the news. Yukon will not fall back an hour this year. I think something has been messed up due to Yukon not changing time. 20201101_220840_5990.jpg
micahsdad
Wearables
yeah but the weird part is its only in the watch. (and my wife's s2) both our phones are fine.
Wearables
I am thinking, if you use manual on phone and bluetooth sync to watch, will this work?
Wearables
Also, try shutdown your phone. Then wait for few minutes, turn it back on. But not Reboot your phone. See if this fix your problem.
