GW4 problem with water lock
(Topic created on: 12-10-2021 09:04 AM)
harshharry
Wearables
I am not able to turn off water lock. Tried resetting my watch. Didn't work. Help required.
5 Comments
Grombay12
Wearables
Are you able to access settings?
Georgine
Wearables
Hi, Can you confirm if you have performed the below setting?
First press and hold the Home key to deactivate water lock mode, shake your Watch to completely remove any water from it to ensure that the atmospheric pressure sensor will work properly, and then tap OK.
harshharry
Wearables
I am doing but of no use
harshharry
Wearables
No i am rebooting watch everytime this happens
Georgine
Wearables
Hi, We suggest you to get the device examined by the authorized service technician to determine the root cause of the issue.
https://www.samsung.com/ca/support/service-center/
