Tap controls for Music not working on my Galaxy Buds 2 Pro
(Topic created on: 08-13-2023 10:41 AM)
SomnathK
Wearables
Tap controls (single tap to play / pause, double tap to skip title, triple tap for previous track etc.) for Music not working on my Galaxy Buds 2 Pro all on a sudden. I am however able to use the taps for connecting/disconnecting phone calls. I have double checked and Galaxy wearable app settings related tousic tap controls are all look correct. I have also tried resetting the bud several times and didn't help. Any help / suggestions from anyone how to fix this issue ?
7 Comments
Helenna
Wearables
Hi, In the Galaxy Wearable app, make sure the switch next to Touch controls is turned on.
Please check that you are wearing your earbuds properly and that the sensors are making contact with your ears.
You can check for software updates through the Galaxy Wearable app and see if they're working again.
SomnathK
Wearables
Thanks Helenna. I have checked all these 3 options and it's still not working. Please note all functions were working perfectly and they stopped working all on a sudden.
T3CHGY007
Wearables
Try resetting your device! That might help!
SomnathK
Wearables
Yes tried the same but didn't work. However it has started working again all on a sudden. So all good. Thanks for your help.
TomyJaya
Wearables
Similar problem happens to mine too, but it can not resume or tap to play after i hit tap to stop.
Trying reset is not working too...
SomnathK
Wearables
For me it got fixed automatically. Try to upgrade to the latest firmware of the buds as well as the phone.
Members_dDc5HSt
Wearables
My single tap now sends a track back 30 seconds. Tried all the settings too, but nothing makes a difference.. Other things seem to work, but I've no way to stop and start tracks except on phone.
