Weather not syncing to Galaxy Fit 2
(Topic created on: 12-04-2020 01:18 AM)
dustineagann
Wearables
I just bought my galaxy fit 2 today but as soon as i set it up, i came accross a problem. The watch won't sync to the weathee and keeps on showing "add current location". I've tried everything including reseting it a couple of times but nothing works. It won't budge. I'm using Samsung S7 Flat. Any help would be much appreciated!
3 Comments
dustineagann
Wearables
I FOUND A SOLUTION! It turns out that my weather app is out of date but samsung doesn't show the latest update for my s7. So i have to download manually the 1.5.79.13 version on google (from apkmirror to be exact) AND IT WORKED!
SummerMei
Wearables
Thank you for solution, mine is works to 🤗
Moderator2
Wearables
Hi dustineagann. Woahh you find the solution by yourself! Hahaha great. Hope it works well😊
