03-02-2020 07:39 AM (Last edited 03-02-2020 07:40 AM ) in
WearablesSolved! Go to Solution.
03-02-2020 09:26 AM (Last edited 03-02-2020 09:33 AM ) in
Wearableswiremash on AKG headphone have a design flaw and when that wiremash is blocked that side will have lower volume than other. I was using eardrops when that happened to me.
Clean the wiremash remove it using sharp object and that might fix your problem.
⚠ If you damage that wire mash while removing just throw it away.
P. S. I did exactly what @Shaggyskunk suggested before I fixed them.
03-02-2020 07:52 AM in
Wearables- Mark as New
03-02-2020 09:56 AM in
03-02-2020 03:16 PM in
03-02-2020 03:58 PM in
03-02-2020 04:05 PM in
Wearables
