120hz with power saving mode?
(Topic created on: 01-21-2022 03:25 PM)
aacash
Galaxy Note
Is there any way to use 120hz with power saving mode. I use to do it on one ui 3.0 but it doesn't work anymore through bixby routines since I have one ui 4.0. any workaround?
8 REPLIES 8
Soopaman
Galaxy Note
aacash
Galaxy Note
This doesn't work anymore on one ui 4.0
Soopaman
Galaxy Note
It works on mine. I have note 20 ultra running Android 12 One UI 4
aacash
Galaxy Note
I have tried it, it automatically go back to standard. Also its not working for other people on ui 4. Just read comments.
Valeriya
Galaxy Note
Hi aacash, Could you share the model number of the device?
aacash
Galaxy Note
Its note 20 ultra Canadian
Valeriya
Galaxy Note
Hi aacash, does it happen only while using Bixby routines? However, I suggest you to perform wipe cache partition and get back to us with the results.
Turn off the device.
Press and hold the volume up button and press and hold the on/off button.
When the Android logo is displayed, release all keys ("Installing system update" is displayed before displaying the Android system recovery menu options).
Press the volume down key repeatedly to highlight "wipe cache partition".
Press the Power key to select. Press the Volume Down button to highlight "Yes" and press the Power button to select.
When the wiping of the cache partition is completed, "Reboot System Now" is highlighted.
Press the Power button to reboot the device.
Soopaman
Galaxy Note
Wish I could help you more. I'm also in Canada using Note 20 Ultra 5G Unlocked 🔓. The only differences I can think of is that I have never used/activated Bixby. Also, I had the power saving mode ON with 120hz prior to updating to Android 12 One UI 4
