Display Problem Nite 22 Ultra
(Topic created on: 07-03-2025 10:12 AM)
RichMe
Galaxy Note
I've problem with my note 22 ultra..why this bright light on top right corner appear..?? Somebody help me to solve this problem..??
10 REPLIES 10
komrel
Galaxy Note
Is it amoled
MarcelEfra
Expert Level 3
Galaxy Note
Hi, I suggest you replace your Galaxy S22 Ultra screen at a Samsung Service Center. There is no other solution than replacing the screen.
Galaxy Note
Hi, RichMe! 🙌🏻
A bright light appearing on the top right corner of the screen on your Galaxy 22 Ultra, which could indicate potential damage or malfunction in the display area.
This kind of issue often occurs due to pressure on the screen when the phone is kept in a tightly packed bag, accidental drops or impact, or prolonged exposure to high temperatures that can weaken internal components over time.
It’s also possible that this light is a sign of early screen burn-in or pixel failure that broke the hardware part of your phone.
Regarding the question Kakak submitted, the most common causes usually stem from pressure while the device is stored in a bag, previous drops or impacts, or excessive heat that may damage internal components.
As for the replacement cost of the Galaxy S22 Ultra 5G battery, based on the official Samsung Electronics Indonesia website, the listed price is 2.938.817,00 for part changing, and Rp2.115.686,00 for general repair services without part replacement.
These prices do not yet include technician service fees or any additional charges that may apply, depending on each Samsung Service Center. The estimated total cost typically ranges from Rp2.300.000,00 to Rp3.100.000,00.
To get more accurate and detailed information, including part availability, I highly recommend visiting the nearest Samsung Service Center.
You can also check the full list of spare part prices via the following link: https://www.samsung.com/id/support/mobile-devices/mobile-sparepart-pricing/.
If you find this response or other Members’ replies helpful, please tap the three vertical dots at the top right of their comment and mark it as a solution.
Hope this helps and may God bless you! 😇
ShīnChan
Galaxy Note
Switch the screen refresh rate to standard 60 Hz,
The issue magically disappears, for now. 😂
But yeah, just temporary. Not a real fix.
ShīnChan
Galaxy Note
Go ahead and try it now!!
then let me know if it works for you🔥
RichMe
Galaxy Note
I've already set in standard mode
ShīnChan
Galaxy Note
It works?
RichMe
Galaxy Note
No..the problem still there
clownnn
Expert Level 3
Galaxy Note
Bang boleh tahu pake casing apa?
Please tell me your casing brand?
