Note 10/10+ volume issue?
(Topic created on: 09-07-2019 01:34 AM)
Samsung_TE0zIIM
Galaxy Note
Having a weird issue with the Note 10, and it was reported by some others as well on reddit. not that many comments at the moment as its still kind of new.
Link: reddit post - volume issue
my issue is similar to these guys, but seems to only affect the keyboard as of now. Usually gets really annoying when im in the room, and tapping the keyboard quickly, the sound would go from soft tone to loud tone and back to soft, similar to "tap tap tap tap tap TAP tap tap tap TAP tap tap"
one of the guys was having this across other apps he was using and condemed it was a hardware defect. since mine only affects the keyboard, so far based on what i can hear, is it more of a software issue? is anyone else having the same issue?
If we are we need to let them know and get the devs in
thanks
2 REPLIES 2
Cassidy
Galaxy Note
Hi everybody, not sure if mine have this problem but yesterday when i was talking on the phone there was a echo each time i was saying something .
@SarathS have also un problem Sudden media Volume Blast At times, her note 10+ media volume explode to max when she is on blue tooth .
After reading the Reddit's article, i am pretty sure then it's only a programmation problem  not a physical conception problem that can be resolve with a update, And you ?
SAMS1
Galaxy Note
No I didn't fix the issue. I wait for the September update as well didn't fix the issue. Did a factory reset as well didn't work. Seems to be affecting other sounds such as click
