Note 10+ battery quality issue after software update
(Topic created on: 04-01-2021 08:00 AM)
avilaohlala
Galaxy Note
After software update UI3.0, battery dropped like crazy. Usually the phone last for 1 day, now it drops even 40% overnight without any usage or open applications.
Tried to wipe cache, put some apps to sleep, clear memory etc, but nothing works. Any solution for this?
2 REPLIES 2
Galaxy Note
Just waiting for the next update patch April 2021..
Moderator2
Galaxy Note
Hi avilaohlala. Have you tried to do factory reset? If you want to try to do a factory reset, don't forget to back up all of your files and data beforehand. Hope it works!
