Temperature warning while charging after USB-C port replacement
(Topic created on: 07-20-2023 03:20 AM)
matt113d
Galaxy Note
Hi all,
The charging port on my note 10 lite has become very worn in the last 3 years and so I decided to replace the charging port. I replaced the board with the charging port, headphone jack, finger print reader etc and everything power on fine, no problems except when I try to charge I get a yellow triangle with a thermometer. I replaced it with the old board and no issues. I tried this a couple of times and reseated all the connections etc and have even tried a second replacement board and I get the same problem. Is there some software BS I need to do for the phone to accept the new part?
2 REPLIES 2
RedDogRabbit
Galaxy Note
If the old board doesn't show the warning, and asking the obvious, but the part numbers are identical?
If you haven't already, Clearing Cache from Recovery, or a Factory Reset may work.
Only other thing I can think of, go to Settings > Apps & Toggle ON "Show System Apps" Middle Right "Hamburger Menu" & Search for USB & Select it. Scroll down to Storage & CLEAR BOTH Cache & Data & Reboot.
See if that fixes the issue for you?
x84
Galaxy Note
I like mine as is just sayin
