02-10-2024 01:27 PM in
Galaxy Note- Mark as New
02-10-2024 01:37 PM in
02-10-2024 01:51 PM in
Galaxy NoteThat's weird for sure! There's no moving parts in the internal storage to make any noise.
02-10-2024 01:53 PM in
02-10-2024 02:01 PM in
Galaxy NoteCan't imagine that either..
I used an OTG device to restore my data from my S20 Ultra to my S23 Ultra, I happened to be in a quiet room at the time, and I don't recall hearing anything..
Same when I'm backing up either device (S20 Ultra to the external sd card) and the S23 Ultra to the OTG.. never heard a sound from either device... or the OTG.
02-10-2024 01:54 PM in
02-10-2024 07:28 PM in
02-12-2024 10:28 AM in
Galaxy NoteHi, Unusual sounds during data transfers on a smartphone are not common, and it's recommended to investigate further. However, without being able to physically assess your device, it's challenging to pinpoint the exact cause of the sound.
Here are a few steps you can take:
1. Inspect your devices: Check both your S24 Ultra and S23 Ultra for any physical damage, loose components, or foreign objects that might have caused the sound.
2. Review the process: Ensure that the data transfer process was completed successfully. If the transfer was successful and both devices are functioning properly, the sound might have been an anomaly.
3. Check for system notifications: Look for any system notifications or error messages on your S24 Ultra that might provide information about the sound.
