What are you using as a replacement for LED notification on your Samsung?
(Topic created on: 09-15-2022 02:02 PM)
RichMan1
Galaxy Note
Curious to see what you guys are using to simulate LED notifications. Do you guys use apps to have Hollow Led effect around the camera that works as LED, or do you not need it & adapted?
If you're using an app to simulate LED around the camera , please mention which apps. Thanks
9 REPLIES 9
RedDogRabbit
Galaxy Note
Holey Light 😉
RichMan1
Galaxy Note
Right! 👌 This is also the one I stumbled upon, but can't seem to figure out if it'll give the light/keep lightning when I get notification.
But it's a great open source app while others trying to rip you off, like AOD Notify.
RedDogRabbit
Galaxy Note
HL will continue to keep the Notification alive until you dismiss it, by opening the app that triggered the Notification.
There's some other options as well.
You can also decide if it follows Do Not Disturb.
RichMan1
Galaxy Note
Ah now I get! Gotta tinker a bit more.Thanks mate 👍 Also look into the app called EDGEMASK. I'm using it in combination with Holey Light, it adds really cool edge lightning & camera halos for notifications too. Nice fonts btw.
Nylah
Galaxy Note
Hi, we are glad to hear that you found the information, you 're looking for.
Kindly write back to us, if you need any further information.
GG2
Expert Level 3
Galaxy Note
Always on display: show for new notifications
Galaxy Note
I use Always On Edge, it uses Edge Lighting, or you can just have it light up around the camera or both
Always On Edge - Not Only LED! – Apps on Google Play
RichMan1
Galaxy Note
Hey if it's not Cprice! 😲 Hope you doing good mate!
I missed this one! I'll download it and test it out, looks very promising!
Galaxy Note
I've been using it for awhile now, I like that you can set up to 3 colors for the edge lighting when you get a notification
