01-05-2021 01:59 PM (Last edited 01-05-2021 02:28 PM ) in
Galaxy Note- Mark as New
01-05-2021 03:14 PM in
Galaxy NoteHi WallyWest,
If you're experiencing Wi-Fi network issues on your Galaxy device, your first option is to power cycle the phone. This can be done by turning off the device and turning it back on. When connecting the device with the wifi, make sure the devices are within 10-15 meters to each other.
If the problem persists, you need to perform the reset network settings on your phone and check if it works fine.
Go to Settings > General management > Reset > Reset network settings > Reset settings.
Note: This will reset all network settings, including those for Wi-Fi, Mobile Data, Bluetooth.
01-05-2021 03:27 PM in
01-05-2021 04:43 PM (Last edited 01-05-2021 04:44 PM ) in
Galaxy NoteI think you mixed up Wifi speed and internet speed. You said:
I run the speedtest.net app to check wifi speeds, I get a maximum of around 180 Mb/s
Speedtest.net is checking your internet download speed.
If you want to see Wifi speed, you can click on Settings → Connection → Wifi→ click gear button on right side of your Wifi name. It shows your Wifi speed.
Seems like is internet download speed slow.
01-05-2021 05:16 PM (Last edited 01-05-2021 05:34 PM ) in
Galaxy NoteThe speed test app tests your data speeds regardless of source of data. So in my case, when I'm connected to Wi-Fi, and do a test, I don't get the full speed that my Wi-Fi is capable of, which is 1Gb/s. When I turn off Wi-Fi and use my mobile data, my speed is faster. This should not be. My Wi-Fi is much faster than my mobile data speeds. Have a look at my results. As you can see, the first column of the results shows the source of the data. I marked the two results that were run with mobile data. The rest of the results are using Wi-Fi, as indicated from the Wi-Fi icon in the first column.
My second screenshot shows what the Wi-Fi settings show for capable speed. But the speed test isn't coming close to those numbers.
01-05-2021 05:25 PM in
01-05-2021 05:38 PM (Last edited 01-05-2021 05:54 PM ) in
01-05-2021 05:47 PM in
Galaxy NoteAlso, if you have other connections going at the background will also slow down the speed. Most ISP require user connect directly to laptop to test.
01-05-2021 05:54 PM (Last edited 01-05-2021 06:01 PM ) in
Galaxy NoteI did as you suggested, turned off the nodes, left the parent node only on, no difference. I just recently upgraded to Gb connection, prior to this I was on a 300Mbps connection, and my wifi speeds were very similar, if not faster on occssion. So there is definitely an issue that is not allowing higher Wi-Fi speeds.
01-11-2021 10:48 AM in
Galaxy Noteplus on top of it being wireless your phone doesn't have the ability to use all of it. and the internet it throttled and not a direct result of your actual speeds.
