Battery Droping S22
(Topic created on: 02-16-2023 05:17 PM)
Clqri
My galaxy s22 battery has been dropping so quick. I got the lowest settings on, I just don't have the minimal homescreen apps on in Power Savings. The battery dropped 4 percent in 5 minutes, and I turn on the phone and unlock it, not even using the phone drops quick. It dropped 3 percent when I first turned it on. When it started dropping fast is when it was on for 10 minutes, 2 minutes of on time, it will be diffdifferent now because I am typing this, but the battery dropped 4 percent with the screen off, and low power. Anything I can do to save battery?
7 Comments
blitzteh
Wait until the OneUI 5.1 update. You're honestly not the only one. I know lots of people who has this issue with the S22. Thankfully it's drastically improved on the S23!
Clqri
Okay thank you!
iFlYSoLo
Do you know how to clear cache from the boot menu? Google that and execute. It should help. Also, if you want to reset, do it from the boot menu. And then don't transfer data, set up new. But the next UI might help.. I would do a reset anyways.
Clqri
I've tried that, I clear android cashe a lot actually.
iFlYSoLo
From the boot menu, using the side buttons. Reset the same way. Perhaps wait. When the new UI cones, do a reset.
Helenna
Hi, as you have already tried to perform Wipe cache partition on your device, then please perform back up and factory reset by following the steps in the given links and verify if your battery draining issue is solved.
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-back-up-and-restore-data/
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-perform-a-factory-reset/
Clqri
I've also done that too, this phone is literally a week old, all updates are done, low power mode says 11 hrs but I only get about 5 on on and off usage.
