tk2019
02-27-2019 06:04 AM in
anyone has the same issue? i have an s9 and since the pie update i feel my battery drains faster! i reset the battery but even than when at 100% in minutes it can lose 10% and when am at 15% it can go to 5% in seconds!!
5 Comments
Shaggyskunk1BLM
02-27-2019 06:10 AM in
"reset the battery"?? lol
Maybe you should start by Booting into Recovery and Wipe Cache - If you find the battery life is still worse than on Oreo - Then I'd backup my device & Factory Reset - The battery life/performance is equal to or better than on Oreo 😉
tk2019
02-27-2019 06:14 AM in
thanks i will give it a try! :)
Dadillac
Beginner Level 4
02-27-2019 05:40 PM in
I've noticed that as well with the battery life
tk2019
02-27-2019 05:46 PM in
i did the recovery and wiped cache and it worked
Moderator_
02-28-2019 05:01 PM in
Hey @tk2019,
Glad @ShaggyskunkS9P's suggestion worked for you (thanks, by the way)! 😊
Cheers,
Sabrina
Cheers,
Sabrina
