04-30-2022 05:25 PM in
Galaxy S- Mark as New
04-30-2022 06:11 PM in
04-30-2022 06:14 PM in
04-30-2022 06:47 PM in
04-30-2022 08:38 PM in
05-01-2022 07:28 AM in
Galaxy SHi, We suggest you to follow the below steps and see if it works. On the Settings screen, tap Battery and device care → Optimize now. The quick optimization feature improves device performance through the following actions.
• Closing apps running in the background.
• Managing abnormal battery usage.
• Scanning for crashed apps and malware. Using the auto optimization feature.
You can set the device to perform auto optimization when your device is not in use. Tap on three vertical black dots → Automation → Auto optimize daily and tap the switch to activate it. If you want to set the time to perform auto optimization, tap Time.
