Best charger for s25ultra
(Topic created on: 02-22-2025 02:30 PM)
Harry779900
Do anyone have idea which 25w or 45w is best for a25 ultra ...i wanna use my phone box cable with it....samsung or any other 3rd party
I also have apple 25w charger ..is it safe to use ?
11 Comments
I would recommend using a 25w charger from Samsung with your a25 ultra.
As far as I know the Apple 25w charger is not compatible with Samsung phones. The cable end on the Apple charger is flat as the Samsung charger cable has an oval shaped plug in.
Harry779900
But i use my apple charger with samsung cable comes in box and it works
WΞS
They do work now. The flat ones are the older lightning cables. They are all USB C now.
To be on the safe side, I would still use the Samsung charger. I'm not sure how much power the Apple charger would give to charge the Samsung phone.
Harry779900
Thanks for ur suggestion i will buy 25 charger then. 😀
RobertZ
In other parts is the world the S25 comes with a 45W charger.
Harry779900
Thts good
jamesy
Anker is always a good third party buy. But yeah stock Samsung is good too
Harry779900
Exactly 😊
