Best charger for s25ultra
(Topic created on: 02-22-2025 02:30 PM)
Harry779900
Do anyone have idea which 25w or 45w is best for a25 ultra ...i wanna use my phone box cable with it....samsung or any other 3rd party
I also have apple 25w charger ..is it safe to use ?
11 Comments
Fatwa
The apple charger is fine to use.
If you are stepping up to 45w, this Anker one is better than Samsungs with respect to bulk and portability. (I have both).
Limited-time deal: 45W USB C Super Fast Charger, 313 Charger, Anker Ace Foldable PPS Fast Charger Supports Super Fast Charging 2.0 for Samsung Galaxy S23 Ultra/S23+/S23, S22/S21/S20/Note 20/Note 10, Cable Not Included https://a.co/d/4G86YJm
Helenna
Hi Harry779900,
Yes, using a Samsung charger is the safest and most reliable option. Since it's designed specifically for Samsung devices and supports Super Fast Charging. Both 25w or 45w will work great, it depends on how fast you need to charge! For the best and safest performance, we would recommend Samsung charger.
Thank you.
